Rranger
Thread starter- Joined
- May 18, 2009
- 475
Changing my starter noticed a wire with insulation rotting off on my 1966 120 hp Mercruiser with a 1974-1976 alpha outdrive. The wire is one of two going through the transom directly behind the Center of the engine and goes into the outdrive. I’m assuming they are for the trim tilt switch. Everything I read says the trim tilt switch is located on the port left side of the gimbal ring on the transom assembly. I don’t see a trim tilt switch. Looks like something might have been mounted but nothing there now? So where are these wires going?
