BoatDrinksQ5
Thread starter- Joined
- Feb 11, 2012
- 377
New to big boats/IO (so bear with me) and have been playing with the trim while cruising to find some sweet spots for different speeds/loads.
2010 Merc Alpha1 190hp 4.3L TKS A14
Aluminum prop - stock- 832834A45 14 x 23 RH 3BL (from what i can tell...) clearly says 23p on prop
Boat: 2012 Tahoe Q5SF, 19'5" 2750lbs
I start with drive all the way down until up on plane - then i trim up slowly until ride seems looser and nose is higher. Notice MPH continue to climb as i do this with same RPM (~3000 lets say). Don't notice any porpoising or bouncing. This is the typical procedure for adjusting/learning correct trim?
Once my trim gauge gets to about the half way mark often my prop appears to blow out. Engine races for a few seconds until i trim down and back-off throttle.
To me....seems like the ride should suffer (bounce, high bow, loss of MPH, etc) before prop should cavitate that bad. Normal?
I am still in the break in period so I haven't had a chance to verify properly my WOT rpms/speed. But you would think a builder would have a good prop from the factory... :-/ Do i see a new prop in my future?
