Trimming motor
wa_ssv197
I have no idea what I am supposed when it comes to trimming my motor.
Everyone talks about having thier motor trimmed up or down. I have a feeling that when the rooster tail starts that I am beginning to cavitate my prop?
Any info with trimming will help me.
Thanks!
soundman2424
Re: Trimming motor
I always start with my motor trimmed all the way down when taking off. As I get up on plane, I start trimming up in small increments until my nose starts to bounce (porpoising) and I trim back down a hair until it's smooth again.
Grand Larsony
Re: Trimming motor
On I\Os there is trim and trailer. Trailer allows you to raise the motor all the way up, whereas trim only adjusts the motor within a smaller range. On outboards, there is usually only trailer (it does both jobs).
On the trailer, the motor should be all the way up (using the up-trailer switch), supported by a bracket or "transom saver" (you lower it slightly (using the down-trim switch) to contact the retention device and the device takes the load off the trailer while traveling.
When you launch, do so with the motor all the way up (raise it slightly to remove the transom saver).
When you begin your startup procedures, lower the motor all the way down (you'll hear the trim pump change tone). Raise it a bit (maybe one or two seconds, it depends). Start motor.
As you pull away and get up on plane, adjust the trim as noted by soundman above. It can be a little different or each boat, and will vary based on number of passengers, loading of cargo, wind & waves, etc.
We usually adjust using the "start porpoising and lower it a bit" method, but you can also hear the engine increase slightly in RPM (and maybe boat speed) when it's trimmed right.
Or have someone show you.
Grand Larsony
Re: Trimming motor
Oh, and when taking the boat out of the water you raise it all the way (using trailer switch), pull it up onto the trailer, place the transom saver, and lower it slightly to make contact.
Honestly, if this isn't something you understand then I'd be somewhat remiss if I didn't recommend getting a bit more educated with regard to operating your boat. Have you taken a safety course? Do you have any friends that are more experienced boaters?
Good luck !!
ziggy
Re: Trimming motor
trimming raises or lowers the drive. thus, raising (trimming out) the bow, or lowering (trimming in) the bow. as stated before, start with the drive trimmed all the way in (down). then after yer underway and planeing. trim for highest rpm. try half throttle planeing. then trim up and watch your tach go up in rpms. short of porposing, highest rpm is trimmed proper. ya might go get service manual #10. all the mercruiser service manuals i've seen have infor about how to trim in them too..
wa_ssv197
Re: Trimming motor
It is a 200hp V6 Johnson.
I have experience with boats my entire life, I have just never owned a boat with power trim. With the boat @ WOT I have it trimmed almost all the way down and hitting ~55mph @ 5600rpm. I am affraid to find out what it will do if I trim it up anymore because of how hard it becomes to steer the boat.
My main concerns are cavitating the prop (which I done and spun the hub on my prop) and if I should trim the motor at all while pulling anyone behind the boat. I was towing my brother and she said that he cold see the prop chopping at the water (this was a 13 3/8x21 Ballistic).
I know have a 15 1/4x19 Ballistic that will be my all purpose prop, the 21 will be for speed and my 17 will be for towing only.
bigskiohio
Master Chief Petty Officer
Re: Trimming motor
if it is real choppy out trim motor all the way down to keep nose down to cut thru instead of bouncing . i usually to as stated above porpising then down a .little
soundman2424
Re: Trimming motor
If you're cavitating the prop like you say, it sounds like your motor isn't sitting deep enough on the transom. When you're "cavitating", does your prop come out of the water when you make a sharp turn? You should have quite of bit of "play" in your trim/tilt before your prop doesn't grab water anymore. I can have mine damn near tilted all the way up before it's not grabbing water anymore. It's needed in the river where I fish, too many sandbars that come up on you real quick!
4JawChuck
Re: Trimming motor
This is how 99% of the boating public use their boats...me too. I also trim down while turning to prevent aerating the prop and to set the boat into the turn.
Home Cookin'
Re: Trimming motor
If you trim too far down on a deep V you can plow dangerously. Usually, trim tabs will do this to you but not ordinary trimming.
Many outboards have trim and tilt, the former being at the lower end and the latter similar to the "trialer tilt". You can run an OB while tilted up above the trim at low speeds (shallow water).
bigskiohio
Re: Trimming motor
mine is a aluminum boat if i run trimmed down it still runs great nose is on the surface @ wot. i also run with my i/o trimmed all the way up to almost trailer position in shallow water at around idle only. Others wont agree on this but my manual says it is okay.
wa_ssv197
Re: Trimming motor
Yes when turning the prop comes out with the motor down almost all the way. I have found that on my trim guage (I have about from 12 o'clock to 6 o'clock on my guage) if I take a turn with it about 5 o'clock the prop will cavitate (21" prop).
The motor is sitting on the transom, can't go any lower.
Boss Hawg
Re: Trimming motor
All good advice-
The above is the best place to start :cool:
Take it out & play with it- you'll soon find the "sweet spot" for whatever conditions your're in at the time - Just take it easy at first till you are comfortable :)
