Trimming Up?
Sierramajesty
Have 1963 28' Owens Flagship - She has lost one of her trim tabs. I just recently purchased the boat and the power trim motor is out of commission too. Is is really necessary on these particular V-Hall boats for the trim? I understand the relativity of having power trim, but is it necessary? :confused:
Pursuit2150
Re: Trimming Up?
It's up to you, since you understand the theory of them. Can you live without them? With an evenly balanced load,ie. people shifting around etc. they are a help.
chrker
Re: Trimming Up?
If I am reading your post correctly, you are saying that you have only one working trim tab and no drive trim (power trim). <br /><br />Regarding your tabs, it would depend on your boat. As Pursuit mentioned, they are good for adjusting the lateral balance of the boat, etc. One could speculate that if it had them on the boat there might have been a reason.<br /><br />But the drive trim is another matter. If the boat you describe is a planing hull, I think you would want to get it fixed. It allows you to position the drive in to get up on plane quicker and with less bow rise (safety). When on plane, drive trim allows you to position the propeller thrust for maximum efficiency and handling (safety).<br /><br />What position is the drive "stuck" at?<br /><br />If I’ve misinterpreted your post, please ignore.<br />-Chris
