triumph 191 F/S ? quality problems
jsambo123
I just looked at a 2004 triumph fish and ski and loved it except for some problems mentioned by the seller and noticed on inspection. The walk through window did not meet the other side of the windscreen when it was closed. The owner, who was very forthcoming, mentioned that it was a $300 job to get the driver side windscreen moved over about an inch. He also mentioned that when the boat was in the water that the boat would flex and the windscreen would almost fit properly. He also said you had to be careful with the trailer position of the boat because of hull flexing. I also noted that the windscreen and deck pieces seemed to be connected with screws instead of through bolted.
It is a well set up boat and I would buy it if not for my concern about the plastic hull.
jsam
