Re: Troling motor on pontoon
If you happen to have a small outboard in your garage not doing anything, then perhaps you could entertain the thought of mounting it to the back of your boat, as I have done. Works great and isn't too heavy. To control it, I use a 5ft. PVC pipe 2inch diameter and steer and throttle from the back seat position....works great You could also opt for steering brackets that turn it via your main motor. Although not the way I did it, photo 3 shows a really easy way to mount it.
My thoughts on this thread have been centered around and electric motor on the bow.
BUT... You got me thinking. If we decide to do some trolling for Crappie etc. a kicker motor would be handy. Also brought to mind the inlaws have(or had) a small outboard in their shop out back. Some where around a 6hp as I recall. I may have to check that out and study on that a bit. Your set up looks like it would work!
Back to the electric motor. I did purchase a 42" shaft transom mount motor and did some looking at my toon. Decided to return it and get the "Pontoon" version with a 52" shaft. Since my fence goes all the way to the front of the deck and I do not wish to block any of the door way with any "Toe Catchers". I got a 2 foot long and 6 inch wide piece of aluminum plate. My plan is to bolt that to the under side of the deck into the front "C" channel, and then back into the first 2 "Z" bars. I then will attach the motor mount upside down to the aluminum plate. The Minn Kota Pontoon version has a swing open clamp for easy removal of the motor when not in use. the bracket will be down underneath the deck out of the way and will only stick out past the rub rail enough to clear the shaft. Due to the stop oh my trailer being center I will have to set the trolling motor to one side or the other of center by about 6-8 inches. Just ordered the motor from here on IBoats last night. Paid just a little more than I could have gotten one from Flea Bay, but felt it worth it to deal with a reputable company and support these forums! Also was still cheaper than buying local and having to pay the Sales tax.
I plan to take some photos and report back when done in a couple of weeks.
