Texas Cowboy
- Joined
- Oct 27, 2024
- 20
I just bought a 1989 Mercury Astro Quickfire with a 24v Minn Kota Edge 70 Trolling Motor (Not working). My issue is, the former owner blew the fuse on the battery side of the harness connector leading from the battery to the Run/Charge toggle switch, as well as frying the switch itself.
The fuse on the battery side is 24V 50amps and the only on/off/on toggle switch I can find online is rated at 30amps. Is the fuse the wrong amps or should I replace it with a 30amp fuse or is there a 24v 50amp 4-pin toggle switch available. It is a 4-wire harness. HELP!
