Trolling motor mount
supercrewser
i have 2010 Q5i S/F and the mounting screws for the trolling motor have loosened up, How do youget to the nuts on the under side to tighten them up?
mvnvltn
Re: Trolling motor mount
Is there a speaker up front you could take out, or only on the Q7's?
supercrewser
No theres no speaker up front.I dont even know how they mounted it at the factory unless they did it during assembly of the hull.
mvnvltn
You may be able to carefully pry up on plate causing the "hidden" nut to bind against the underside of the fiberglass allowing you to try and tighten the top screw. If that doesn't work, it looks like a good time to put in those two extra speakers you've been wanting :)
