Hello, I have an aluminium 1964 14" Texas Maid. When I bought it, it came with a 27# Minn Kota 40t(?) w/ 5 speeds. On Feb 2nd I bought an EverStart 94 720 amps, 115 amp hour 27dc-6 battery to run it. On my first trip out last Sunday I got about 2 hours trolling on speed 4 which was barely fast enough to make a 4" rapala wiggle. I took the battery back to Walmart and they load tested it for over an hour and everything checked out OK. When I got home I took the prop off the trolling motor and there was a crap load of line wound around the shaft between the t-pin and the actual motor. I cleared that all out and it seemed to spin better. Today we went out on a full charge and were running at 3 speed which is perfect rapala wiggle now. I got about 3 hours before it died out. All I have attached to the battery is a Garmin 100 fish finder and the trolling motor. This seems awfully short and I seem to remember back 15-18 years ago having a 24# or 27# pushing a 12ft sea king for 6-8 hours at the same speed.
When the battery starts to die the fish finder shuts off until I turn the trolling motor off and then the fish finder comes back on. The fish finder has a battery meter in it and when it was "dead" the battery was at like 10.2v and when I turn the trolling motor to 3 it would drop to 7.7v and then the fish finder would shut off.
When I had the battery tested it was pushing like 12.7 volts and like 680 cold cranking amps which the guy told me was good because the battery is rated for 600 cold cranking amps.
Now does this seem like a trolling motor or battery issue?
Trolling motor looks to be an older one because the newer ones of the same model have a battery meter build into the head.
