Re: Trolling Motor Wiring
You need to provide more information to get an accurate answer to this question. What is the voltage, and what is the amperage of the motor? Without these two numbers, there is no way to answer the question. Using the same size wire that is coming out of the motor is wrong. It will need to be larger, as the distance is increased. Also, is the wire length truely 17 ft each way? You may find the wire to be longer depending on how you have to route it.
Also, you will not lose amps, regardless of the wire length. You will lose voltage. You will lose voltage on every wire. Size and length is what determines how much of it you will lose.
