lighthousehunter
Thread starter- Joined
- Sep 18, 2014
- 7
Hello, I realize there is a sticky for this, but the topic I need about basic boat wiring is missing the image pictures and diagrams. ( http://forums.iboats.com/forum/boat...iring-diagram-plus-navigation-switch?t=225399 )
I have a Salt water model Great white Motorguide (30-35 lbs thrust, I believe), and it's factory attached pigtail is cables of what I believe to be #10. The writing is kind of worn on it, as I bought the motor second-hand. I am going to run the positive (red) to a 50amp Motorguide breaker, which is the one recommended in the manual by the manufacturer, which will then continue as #8 marine wire to the deep-cycle marine battery. Reading other posts online, I read that #8 or #6 is best, so I was not entirely sure why Motorguide chose to use #10 for the pigtails... (I assume since it is cheaper...). Now my question, would I have a problem directly attaching the Neg cable to a battery? Or if I need to run a few more feet, can I use more #10 cable or do I need to up it to #8 even if it is only a short run? If so, how do I go about increasing the wire size inline? Do I use a terminal block for this? I should mention as well, the wire will be in "open air", I read enclosed wiring can cause more heating and thus carry less current.
Thanks for any help!
Mike McGuire
Mike McGuire
