Trolling Plate
Starcraft5834
I've got a 20ft cuddy with 3.0 140 4 blade.. went trout fishing 2 weeks ago in Seneca Lake-NY. at base speed was going to fast for trolling.. almost 5mph. Friend of mine suggested a trolling plate.. I bought an Easy Troller from Ironwood Pacific Outdoors ($110). Went back to Seneca two days ago, Im down to 1.9-2.2 mph... we caught (2) Salmon.. If anyone wants the perfect solution on how to use the main engine, this works perfect. The alternative would have been spending $500-$1000 on kickers or electric....which I did not want to use... This works...and is very well made.
Teamster
Re: Trolling Plate
The other option is a Amish Outfitters trolling bag,.
dingbat
Re: Trolling Plate
What your idle speed and what size prop are you running?
I had the same 3.0, 140 combo on a 19' ft cuddy. Had no problem trolling at 2.0-2.5 mph
Starcraft5834
not use to this new edit feature lol.. Ive got a 4 blade... plate slowed me down from 4.7 to 1.9-2.5. caught a salmon in first 10 mins of use.... it works nicely
dingbat
Blade count doesn't mean anything. What size prop do you have? What RPM?
Starcraft5834
15x16. did not look at tac at idle speed... it's a good size prop,, pushes a lot of water... my issue is solved now... i thought about messing with idle.. bes tto leave it alone,, im happy with outcome
