trolling with main motor
rhuble64
Does anyone know if idling for long periods of time when trolling will harm a evnrude 120 v4? it doesnt seem to bother it. but i dont want to mess anything up.
jash1178
Re: trolling with main motor
Yea, I am wondering the same the same thing about my 89 Evinrude 48SPL.
crb478
Lots of people do it without ill effects. If it was me I would make sure to always run with seafoam or a carbon guard in the gas to help with carbon buildup. I would also run it wide open for a while after I had been trolling to help with any buildup. I prefer to use a kicker motor, but like I said there are a lot of people who troll with their main motor and do just fine.
rhuble64
thanks, my kicker motor kicked the bucket, been using the 120 until i find another kicker.
wellsc1
I have trolled with a 200 hp Black Max, but oil injection varies mix to help prevent carbon build-up. ...with a 40 hp Force with mixed fuel with no ill effects, but it ends with a long high-speed run back to civilization. and with a 90 hp Yamaha, but also with oil injection. No ill effects.
Boss Hawg
I do with my 70hp Johnson (pre mix) but as others have stated i "blow the soot out" every so often :D
Have had no problems :cool:
ryanbatts
Re: trolling with main motor problem
hi ,i , started my motor up with my trolling motor connected to the starter battery and my trolling motor wont work now. did i ruin my trolling motor ? it a 50 pound thrust trolling motor i got it 4 my birthday :eek::(
JimS123
Yes, blow the soot out once in awhile and have had no problems.....yet.
A good analogy is smoking. One pack a day for a year - will you get cancer? Probably not. 2 years, 5 years, 30 years.??? In other words, its a progressive thing.
The more you idle it, the worse it will get. If you have a VRO system I would be less concerned. But if you pre-mix at 50:1 eventually you will get gunked up. I'd use engine tuner religiously if it were me.
