trophy 2152 stereo
Hi Everybody
l bought a 2008 trophy 2152 and am trying to put a marine stereo on it ,l have the electrical layout of the boats wiring but l cant find where they finished the end of the stereo wires it does have the stereo fuse on the console and the wire comes out from the fuse but l cant trace it it goes taped with a lot of wires ,it should have a positive wire always connect to the batterie also but l dont know where it is can any body help at all or can refer me to someone who can help l am sure it has the wire for the stereo but l cant find where the wire ends up ?
Thanks Joe.
chrclo
Re: trophy 2152 stereo
For me the best bet is to wire the stereo from scratch. I had issues with my boats wiring being substandard. Once I started from scratch all my issues were corrected.
Silvertip
The hot and 12 volts always on (memory power) do not have to run all the way back to the battery. You have those two requirements, and ground right at the fuse panel. If the boat was wired for speakers check the color of those wires. They should be hanging under the console or possibly terminated in a large multi-terminal connector.
Re: trophy 2152 trolling
Hi Guys
l have a trophy 2152 with a mercruiser 190 and alpha1 gen2 drive ,when trolling at very slow speed the boat go's from left to right to left to right all the time it is very frustrating l even changed the power steering to hydrolic steering but for nothing doe's anybody have the same problem ?And what should l do ?
Thanks Joe.
