MakO17 90 EvinrudE
Thread starter- Joined
- May 9, 2010
- 28
i have a 1997 evinrude 60 degree looper v4 90 hp. when its time to start my engine and it hasnt been ran in a few days, i have trouble starting her.. the only trick i have learned for dealing with this issue, is i take the engine cover off and locate the linkage that connects both sides of the carb butterflys. I manualy give that some play while my buddy starts the key at my command. it takes a few goes of playing with that lever and also the timing lever at the same timewhile the engine is bein started. after a few goes she starts right up, while i am manually slightly holding the butterflys open keeping the motor running i tell my buddy to put the motor into neutral with a bit of gas so she stays running, at this point the engine will warm up and i can slowly bring her back down to neutral. this has seemed to help me however, i would love to figure out the root of the problem becasue my engine never did this before. after a bit of running up and down the intercoastal i can leave the motor off for a bit and then start it up with one turn of the key. i replaced the o rings and gaskets in my primer solenoid but still nothing.. if anyone could please let me know how to adjust whatever needs to be adjusted... please. thanks alot in advance
