Re: Trouble reattaching top to hull
Can you use a few ratcheting tie down straps. Don't ratchet first one down tight. Do each a little at a time. Compare measurement to cap as you tighten. Then when close, lower down and remove straps one at a time. Be sure to have no twist in straps, keep flat to hull. At least thats how I'd do it.:joyous: Hopefully someone more knowledgable will chime in. Good luck.
