89 Johnson 110. Boat has been stored for 2 years.Got boat out and did normal things before trying to start it with ear muffs.Discovered quickly after cranking motor a few times the primer selonoid was bad and leaking.Replaced that and it started.Lots of smoke and rough but kind of expected that.Put it in the water yesterday,it started fine so just wanted a short time out to see how it would run.First few minutes were rough then for a few minutes it ran ok,Shut it down then it would not start.Adjusted red tab on primer selonoid just slighty and it started but still ton of smoke and ran awful,kept cutting out and could barely get half throttle.I know i should have drained old gas and oil and plan to do so but not sure where to go from there.Any help would be greatly appreciated!
Thank John.....
Thank John.....
