Trouble starting 4stroke high elevations
aeviaanah
Going camping this weekend and I had trouble starting my outboard at this elevation. Motor is 2012 Mercury 15hp 4 stroke. Starts fine at 100ft elevation but takes tons of electric start/pull start to get goin at 5700ft. After I get it goin it seems to run fine. Any suggestions to getting it started easier? Any suggestions would be greatly appreciated.
belairbrian
Re: Trouble starting 4stroke high elevations
The carb is jetted for sea level so 100ft MSl is not an issue. But at 5700 ft MSL the thinner air is essentially causing a flooding situation. Thin air same amount of fuel means rich mixture.
Might try no choke starting or treat like its flooded.
aeviaanah
Ok I'll try that but what do you mean treat it like its flooded?
