trouble with 1995 johnson 150 HP has no power
tony11905
this motor i have is a 1995 johnson fast strike v-6 with 6 carbs, all cabs have been rebuilt ,stater replaced,fresh fuel,new plugs, new impeller in the lower unit. problem im having is the motor starts right up and runs fine on muffs but as soon as i but in the lake to try it out, it would hardly move rpms would go over 1500,im not sure what i did wrong but i need help please anyonethat has seen or has this problem and has the awnser please help me. out.:confused::beaten:
boobie
Re: trouble with 1995 johnson 150 HP has no power
If the stator was replaced, is your timing advance on the top of the mtr working free and properly ??
tony11905
how can i tell its the timing advance? is there pictures of it or a diagram. thank you
boobie
Leave the key off, rotate the prop and drop it in fwd gear. Then advance the throttle to WOP. You should see the linkage on top of the mtr moving and the carbs going to full open position.
tony11905
ok that works , what do i try next? anyone please!
boobie
Pull one plug wire at a time when you have it running and see if you have a dead cyl or two.
tony11905
i do have two dead cyl ,but how if the stator was replaced with a new one?
w2much
Try switching coils.
boobie
If it's not the coils it might be a bad power pack. But before you get into the p/p check all the ignition ground connections on the mtr. Coils and all.
