Trouble with a Merc water pump!
waterinthefuel
I was helping my father ready his 1978 Merc 70 for the spring. We changed the lower unit oil, spark plugs, charged the batteries, etc. He decided to start it to make sure everything was hunky dory. We started it on muffs and the water pump would barely pump. I adjusted the muffs and it became intermittent at best. It would pump fine for a few seconds, then completely stop for a second, then pump again, then stop. The water coming out of the tattle tale was certainly warm, but not to the point of burning your hand. This was only after idling it for a couple of minutes. It is warm outside, mid 70's for sure, and the water coming from the muffs was room temperature.
The water pump was replaced either last year or the year before, so do you see something as being wrong, or is it because it's on muffs that it's acting up? The engine purrs like an absolute kitten, it should, as my father put 1000 bucks into new electrical parts for it when he inherited it from a relative. We don't want to drag it 30 miles to the lake only to find out the water pump is so-so and we'll have to drag it all the way back.
Aren't muffs not the best way to determine how well a water pump works?
rabeck5792
Re: Trouble with a Merc water pump!
you should replace the impeller every year,muffs are ok
rickdb1boat
I would put the lower unit in a tub of water/trash can and run it. Sometimes muffs can give errant results. The pump should not be bad in 2 years, but it can happen. Also make sure the pee hose is clear by running a small wire in it...
Yepblaze
I'd shoot a blast of water up the tattle tail while it's running. It just might be a small bit of algae left over from last year.
Silvertip
Honorary Supreme Mariner
Using muffs is definitely not the way to test a water pump. Pressure from the hose "forces" water through the system so even you didn't have an impeller, water would pass through the engine.
