hotrod53
Thread starter- Joined
- Oct 16, 2009
- 509
Three times now I had a carb needle stick in the UP (closed) position, and not all on the same carb. These are the rubber coated needles. Each time I took the carb off and the bowl as dry, I remove the float and have to grab the needle/spring with needle nose pliers to free it. I have cleaned the seat with a Q tip and wiped off the rubber coated needle. I guess replacing the needle and seat is thr right thing to do. If I replace them, should I use all metal or rubber coated needles?
In the meantime I removed the fuel line and let the motor use up the fuel in the bowl when I shut it down, maybe I should get in the habit of doing that all of the time?
