kwoolard
Thread starter- Joined
- Feb 9, 2003
- 420
I have a 1974 40HP 2cyl. Johnson. I have recently had the carb rebuilt by an outside source about 5 months ago. It ran smooth at idle, the best it ever has, as soon as I got it back and put it on the water. Here lately, it is starting to die out at idle. I have adjusted the idle speed valve out a turn and it ran fine for a few trips out. It then started the same problem of cutting of at idle. I replaced the spark plugs and installed with the right gap but no improvement. However I noticed that the spark plug tip, where the plug wire boot attaches to the plug, was loose and was a blueish color, as if it had overheated. I tightened it up and ran the engine but no improvement. I also noticed that the coil inside the plug wire boot was rusted bad, so I thought it may be a bad connection. While the engine was running (i won't be affended if you call me a fool for doing this) I tried to wiggle the plug boot to see if it was loose and was not getting the proper connection to the spark plug. Well it gave a bit of "shock" to my arm. I checked the manual and other sources and they say that the spark could be jumping through the insulation to the block and shorting out. Is this possible? What else would be causing my idle problem?
