Troubles with 8HP
Jeff J
I believe the safety switch on those ground the magneto. If you have spark with the safety clip installed and no spark with the clip removed then it is working properly.
Kissdude
Thank you for that info.
Kissdude
So the safety switch is working then, now just have to figure out why it won’t start. I put 6 drops of gas in as advised but it doesn’t want to start, not even a fire at all.
Kissdude
Would starter fluid be ok just to see if it fires?
Starter fluid is just fine.----See posts #7 & 8.----Checked flywheel key ?---Or no idea why that is important ?
Kissdude
No I haven’t had time to check flywheel key and assume it’s important because nothing would turn when I pull. I pull the cord and have compression, spark and a sore arm but maybe I’m missing something.
Kissdude
I also wanted to say, I’m asking about starter fluid cause when I put drops of gas in nothing happened. Maybe have a plugged carb? Don’t understand why it didn’t fire with drops of gas and spark.
????----If the flywheel key is missing or sheared the timing will be way off.-----Up to you to do some simple checks.-----Remember no one can see , touch or hear your motor.
Kissdude
I will keep that in mind thanks but, if the key was missing, would I have compression and spark when I pull the rope?
Kissdude
Checked the flywheel key and its there. still can't get it started and a shot of fluid didn't do anything as well. Any more Ideas?
