Anthonym2
- Joined
- Apr 6, 2016
- 60
Hello All,
I had my boat out (1980 Beretta, 140 Mercruiser I/O) over the weekend, when It suddenly shut off while running. Somehow I think the bilge pump and blower switches got turned on and were running for about 20 mintues or so before everything shut down. I now have no power at ignition. I checked the battery and charged it overnight - then took it to autozone to have it checked out (They said it was in good shape). I put it back in but to no avail.
From what I have read - I should check the fuse box on the starter solenoid and the 50 amp circuit braker near the front of the engine. Here are my questions.
1. Do you think this is the right course of action?
2. I have read varying amps for the fuse box on the solenoid - 55, 90, and 100. How do I know what to replace with? Can you tell by looking? pic attached
3. The breaker does not seem to "reset" properly and the button just jiggles around a bit and only pushes in a quarter inch or so, is this normal? pic attached
4. Where do I get parts and know I'm getting what I need? (Can you tell I'm a first timer yet?)
I'm thinking that the bilge pump ran until it fried and shorted the system out?
Thanks in advance - let me know if you need any more info!
