76Raven200
Thread starter- Joined
- Sep 18, 2008
- 17
So, Yesterday I funeralized the hull that my log-in came from. Goodbye to 1800 lbs of saturated foam and delaminated hull.
I'm have removed the motor and i/o drive and want to disconnect / salvage the tru-course steering.
Here is my question: How do I remove the shaft from the drive that has the gear on it? Part No. 17 depicted below. Do I have to completely remove the out drive from the block? If so, is the rectangular portion of the housing filled with oil?
Thanks for the feedback!
JPM
JPM
#14, there on each side, remove the 2 bolts, remove caps ,carefully slide drive back and away from the ball gears and safely support the drive from falling .
