Truck Air Conditioner Help
Sprig
I noticed yesterday that of 4 dash vents only the vent on the far left drivers side is blowing cold air. The other 3 vents are blowing uncooled air. It?s a 2009 Toyota Tacoma double cab 4x4. Anyone know what the problem may be?
Sprig
No, all the vents function the same, you can?t adjust any individually.
MTboatguy
Sounds like you have diverter door stuck in the dash, on my Fords I have 3 separate doors, on my Subaru there is two doors, the Silverado has 4 doors.
Sprig
If it?s a diverted door do you know I& that is an expensive problem to fix?
MTboatguy
I would start by figuring out where the A/C Heater Blend Door Actuator located and make sure it is working as it is suppose to, you can get a new one from Autozone for about $40
