scrit9mm
Thread starter- Joined
- May 31, 2011
- 425
I was installing a new set of trailer lights on my project this weekend and when I would press on the brake the lights would turn off, also the blinkers would blink on all the trailer lights. I figure it is a grounding issue, so here are some questions...
Does the trailer have to be attached to the vehicle to create a ground?
What constitutes as a true ground? Could I put the ground wire on a negative terminal of a spare battery to double check that it is indeed a grounding issue?
How can I check if the ground is properly set with a volt meter?
