JASinIL2006
- Joined
- Feb 10, 2012
- 5,729
I went out to the garage to get my boat ready for a weekend outing only to find the right tire was totally flat. I jacked up the trailer and pulled the tire, thinking I must have run over a nail or a screw in our alley, only to find about a hundred little steel wires sticking out of the tire where the sidewall meets the tread. Clearly, this tire is toast. We just got back from taking the boat with us an 1800 mile round trip to Northern Ontario, so in way, I guess I'm lucky it didn't go flat until now.
It imagine one of the steel belts ruptured and hosed the tire. (Perhaps I've taken one too many curbs when making right turns!) The tires are Karrier radials, and while I've got pretty good use out of them (they're about 5 years old and have thousands of miles on them), I think I'm going to try Goodyear Endurance tires. The Karriers were load range C and the Goodyears will be load range D, so I'm hoping they'll be a bit more durable.
One question for the tire gurus: The tires I pulled off the trailer had an odd wear pattern: the center of the tread was pretty well-preserved, but there was noticeable wear on the outside edge of the tires. In fact, the tires were fairly smooth on the outside edges. A bit of web research shows that pattern is associated with under-inflated tires. That is very puzzling to me, because I am religious (the Admiral would say I'm obsessive) about checking inflation and keeping the tires at the max recommended inflation. Any idea what gives with the uneven wear pattern? Both tires exhibited it.
