egclassic
Thread starter- Joined
- Dec 13, 2009
- 128
I just picked up this motor last week.
First thing I did when I got it home was to see if I could get it started, before I drop some money into it.
It fired up right away.
I ordered 3 carb rebuild kits w/floats, water pump kit, gearcase lube, new t-stat, spark plugs and fuel pump repair kit.
I soaked all 3 carbs in cleaner, and blew them out with compressed air. Rebuilt the carbs, paying close attention to proper float adjustments. Replaced all other parts listed.
Today I tried running in a barrel. It starts up fine, but does not seem to want to idle very well. also, seems like I have gas leaking from the carb opening(s). I have not done the "link & sync" yet.
I did mix two gallons of fuel and oil, with most of a can of seafoam. While running I sprayed the remaining seafoam into the carbs. At first, it would only run for a couple seconds and die. It did eventually run progressively longer but I had to keep working the throttle, then it got dark on me. I checked compression and had 120 across the board.
Am I correct in assuming these carbs have no adjustments? What about the fuel spilling from the carbs?
Thanks in advance.
Thanks in advance.
