Re: Trying to crank a 50 year old model engine
I had a few of those Cox .049's way back when. I also graduated up to the bigger engines; "O.S" brands mostly and I had a "SuperTiger" 0.40. I still have a couple of them from my collection, and actually dragged them out of the attic a few months ago.
On the 0.049, that spring 'thingy' around the prop shaft is what you use to start it. The fuel can be had at an R/C model specialty shop. I had to hunt around to find one locally in my area. Typically there is about 25% nitro-methane and then synthetic caster oil in the blend along with a base fuel.
I actually tried to use gasoline and some 2 stroke oil to see if I could get mine to run . . . not so good. Then I added some alcohol to the mix and got it to run for a few short blasts.
On the Cox .049 the fuel is in the engine base, so I imagine that is all gummed up after 50 +/- years. Time to get out the heavy solvents (carb cleaner, starting fluid, etc). I bet it will work once it is cleaned out.
The glow plugs generally run on a 1.5 volt battery, but I can't recall if the .049's are different. If you use too much voltage, the glow plug will quickly blow out.
Enjoy your new found treasure.
