trying to fix trim gauge
buddybarnhill
okay so i figured out he reason my trim gauge isnt working is cuase the wires were all dry rotted at connection was broke so i rewired the whole trim system and now i just have one question does ur boat have to be in the water or running on ears for trim gauge to work??
d.boat
Re: trying to fix trim gauge
If it's wired properly, the gauge should work when the key is on, but the motor doesn't have to be running. Just turn the key on (don't start the engine) and tilt the engine up and down, the gauge should work.
buddybarnhill
Thank You So Much I Appreciate It Ill Have To Work On The Wireing Some More Cause Its Still Not Working
