Trying to install a gen 4 502 mercruiser, need help!
Tahiti warrior 502
I am looking for wiring diagrams for a gen 4 502. I could also use any diagrams on how to hook up water and oil lines. If anyone knows how to find this info it would be awesome!! I'm trying to re install the motor that I didn't take out.. I am trying to make sure I hook everything up correctly. Thanks
have you looked in the factory service manual?
if you did not get rid of adobe flash, you can still view them in the library on
otherwise you buy them from
you can also put your serial number in BAM to see exploaded views of the parts manual. https://www.mercruiserparts.com/
it is illegal for iboats to post versions of the manual (copy right infringement)
