I have a '91 Grumman 19' SF boat with a 70 'Rude motor.
The boat is used in freshwater, The Thousand island, at Clayton N.Y., on the St. Lawrence.
I have a good running British Sea Gull I want to use a trolling motor.
I just got a mount mount for the outboard, it has the tallest lift I could get 13 1/2".
It gets the motor in the correct water level, (2" above the pinch bolt, so it'll start and run good).
The problem is when I lift the motor up, the lower unit is STILL at water edge, when I get on plane, the lower unit is in the water.
I was told?? by someone on line, (and it's got to be true- I saw it online!), that these motor's mounts are too fragile to tilt to store.
Any ideas how I can raise the motor a few more inches??
Joe
This is the problem.... I like "odd things", and I run into these problems ALL the time!
Joe
