tubing behind bass boat
jlsmith
I have a 17.5 foot bass boat and want to try to pull a tube. I have heard you can conncet the the stern tie down eyes. What is the best product to use for this that won't get into the prop. Once to connect the two rope to this bridle or rope what keeps the tow rope from getting into the prop. Any pictures or diagrams will be helpful.
04fxdwgi
Re: tubing behind bass boat
Just use a bridle, store bought or home made. I made one from S/S cable and ran the cable thru some swimming pool "Noodles" and put a pool rope float next to connection point in the center of the bridle. Floats like a Cheerio, even when backing and it's easy to see, too. Bridle length should be 2-3 times boat's width.
blifsey
Tube ropes and bridles float so chances are slim it will get in prop. Just idle away until rope is taught and you should be fine.
barus243
The store bought bridle is the way to go. And if you ever end up not tubing then it can be used to connect a drift sock also.
