tune up-gas additive
katbird
my merc dealer told me to run the gas additive in my old merc. he said it was the same as decarb but you add an oz. to 6 gal. of gas. told me to do this on every fill up. I have already used 2 tanks like this. theres not any excessive smoke and the motor seems to be really strong[115 hp]. I was also told not to put it in every fill up that it would keep the cyl. walls washed down. I wounder which one is correct.
ZmOz
Re: tune up-gas additive
It will probably keep your engine a little cleaner, but it does NOT replace a decarb. Also I would suggest using a small amount of seafoam in every tank rather than whatever you're using. 1 ounce of anything in 6 gallons of gas will not decarb an engine. That's a 768:1 ratio.
