Tune up - Ignition Sensor?
Lift12
I am planning to perform a tune up on my 1989 5.7 engines with Thunderbolt IV ignition. I expect to replace the cap and rotor, plugs and probably wires.
I have not yet dismantled the distributors the inspect the ignition sensors. Assuming there are no signs of deterioration, should they be replaced?
achris
More fish than mountain goat
Determine which sensor you have, 2 wire or 3. If it's 3, leave it be. If it's 2, check for corrosion of the exposed circuit board and solder connections. Replace if corrosion is present.
Chris.....
Lift12
Thanks Chris, and thank you for your very informative sticky about the Thundervolt system.
