Tune Up Specs 1973 Johnson 50HP 50ESL73R
Captain Bravo
Yes, it is a built in tank. I drained it as best I could earlier this summer. I put a couple gallons in it, and it was running quite well a week or so ago. Then yesterday it fell on it's face. I am OK with trying a different tank. I'll see if I can borrow one somewhere.
Nordin
Sounds like it is running on one cylinder.
Check for spark again with a timing light when running.
I do not trust the cheaper inline spark tester, that is why I suggest you to use a timing light. I have use these cheap inline tester and got spark (it flashes) and when I check with a spark tester with adjustable gap it fails.
Also check for spark with your spark tester with a gap of about 3/8 in or more.
Then if you have spark on both cylinders check the compression.
Captain Bravo
Nordin, dropping a cylinder was my first thought too. But it didn't sound any different as far as being smooth. It didn't sound like it was missing, it was just down on power.
I checked the spark earlier this summer, and got 3/8" on both cylinders with my adjustable spark gap tester. I also tested the compression, and got 160 on one, and 165 on the other. Which sounded pretty high for a 2 stroke, but at least it was within 5 pounds of each other.
I need to do some of these tests again, which I am hoping to do tomorrow if the weather will cooperate. Thanks for the help.
Checked the flywheel key ?-----Replaced water pump impeller ?----Tested the overheat horn ?----Checked fuel pump diaphragm ?-----Yes , those compression numbers are near normal for that motor.
Captain Bravo
Racerone, I hadn't considered the flywheel key. It was running full power and just fell on it's face all at once. Water pump impeller is new. Fuel pump is new. Thanks on the compression. I'll try to check the flywheel key tomorrow.
Edit: Sorry, forgot to mention the overheat alarm. I am not sure how to check that.
jimmbo
You are going to have to redo those tests, something has changed
Captain Bravo
Jimmbo, that is pretty much what I was thinking. Planning on taking it from the top tomorrow. The weather report looks OK, only 20% chance of thunderstorms. Would love to take it for a cruise tomorrow evening.
Captain Bravo
Update. The spark plugs look good, compression is good (160 165), both coils throw a 3/8" spark, and fuel flow looks good. All remain unchanged from a week ago. So I figured fuel flow. Borrowed a portable outboard tank. Had the wrong fitting, so I bought a hose barb from the hardware and ran my line right to it. Bought new gas, and used Penzzoil TCW3 that I opened last week. Put it in the lake for a test drive. It was a little hard to start, but not bad. Then I got results very similar to last week. Got about 150 yards from the ramp, running strong, then fell flat on it's face. Got is restarted, but it was difficult, but any engine load, and it would die right out. Got back to the ramp on the trolling motor. That took a few minutes. Backed the trailer into the water, and then was able to get the engine started to load it on the trailer.
If this was a car, I'd say the coil was losing power after it warmed up. But it isn't. I got this engine 9 years ago. It didn't run then, and I replaced the rectifier and stator with parts from CDI Electronics. I don't know if that will tell you anything or not, but there it is.
I haven't ohmed the coils yet. Any idea of what I should be looking for on that test?
Thanks guys.
jimmbo
Heat can cause components to fail, then by the time you get home, the affected part has cooled and is working when you troubleshoot.
Captain Bravo
I will try to do that Saturday. Weather is supposed to be good. I would really like to get this going. It is a lot of fun when it works. :)
