tune up turns into thousands of dollars fix??
huntingdeer
87 alpha one mercruser with a 305,ok so i went to replace the bellows and found water in the drive shaft bellow witch did not leak.I looked around and seen a crack on one of the housings where someone hit something and it cracked.I was thinking about jb welding it.As long as it is water tight it should be fine right? And also how do i get that shift leaver off?I do not have the money to replace the unit.I thought i got the boat on a deal but things are changing.
Bt Doctur
Re: tune up turns into thousands of dollars fix??
Cant see anything in the 2nd pic. post some more pics a bit further away.If remove the slide is all you need ,go inside the boat where the shift cable connects, loosen the 2 square bolts on the plastic slide, pull the slide off taking care not to lose the square bolts, and pull the core and slide out from the rear housing.
http://www.boatfix.com/merc/Servmanl/6/6A2R3.PDF
ktbarrentine
I see the crack in the second picture (at least I think I do).... but that should not have let any water into the drive bellows as there is a primary seal on drive nose to prevent that. If that seal was compromised, then we have a diffent story.
Bt Doctur
Did you glue the rubber ring in place when you installed the drive? That lets water into the bellows. Damaged mounting gasket or water O ring would let water in that area too.
huntingdeer
the seal looked new and it was inside the bellow like it fell in idk.all i know is i seen a good crack in it.
huntingdeer
the first pic the crack is at the top of the decal.
huntingdeer
im replacing all gaskets their.I found a kit for 20 dollars that has shift bellow and gaskets.no i have not replaced the bellow yet but i am about to order it.Whats the glue called?
Don S
Why don't you post your pictures big enough to actually see.
ktbarrentine
Bellows adhesive.... by the way, it is called a bellows, even when you are talking about one (like a fireplace bellows)... "bellow" is the noise you make when you have to replace one!:doh:
fishrdan
JB weld "might" seal it up, but I wouldn't trust it. Welding would be a better "fix", but a used bellhousing would be easier/cheaper/quicker/better.....
crack circled
huntingdeer
ok i pulled everything apart in the rear and im wondering if the Gimbal Bearing is bad.It turns easy but a little loose.And by that i mean what is loose is where the drive shaft goes into.I would hate to replace it too.Ive already got a big bill going haha.
