Turbo Prop I or Cabellas Performance Prop?
Shawk
Love all the "stuff" I've already read through here.... :)
I've had Turbo Props on previous boats and they seemed to really perform well. Cabelas has a "Cabelas Performance" prop and I'm curious if these are any better or worse... I'll probably go with the Turbo unless I'm convinced otherwise. Thanks in advance!
Bayliner 2050 21'... 305 V-8... approx 3500lbs... Thank you!
All the best!
Steve
Shawk
Re: Turbo Prop I or Cabellas Performance Prop?
Anyone? Thanks!
Shawk
Anyone running the Cabelas prop?
Bifflefan
I say stick with what you know.
There are a ton of different props out there that make claims to what they do best.
For me I have a factory alum, a 3 blade SS and an old michigan wheel props.
I use each for different things. As for a good all round prop id have to go with the alum one.
I found them at my local marine repair shops 2 used and one new.
As for the Cabella's, ive never used one so i dont have anything to add.
Again just go with what you know and like.
Dhadley
The Turbo I has a little more technology built in than the Cabelas prop. Very close but not exactly the same design.
Shawk
Thanks for the replies guys... I'll probably go with the Turbo.
All the best!
Steve
