Turbo TXP on a sport's cuddy
jestor68
Re: Turbo TXP on a sport's cuddy
After spending a few minutes on the Turbo web site, looking at their recommendations for "deep drive application" stern drive props, I came up with two recommendations.
In 3 blade; the Vector in the 14.5 X 23 size. The Turbo 1 is also available in that size, but is a step down compared to the Vector.
In 4 blade; the 2+2 TH, in the 14 X 22 size.
The Fusion 4 is intended for specialty hulls, so may not be well suited for your traditional V hull.
It seems that most of the Turbo props you're looking at are intended for outboard applications with higher than normal mounting heights.
Tail_Gunner
Pretty simple i have them all aside from the Fusion, The ot4 is noted for carrying high loads very well has a very high rake angle along with a fair diameter. I will admit i had forgotten about the aggressive cupping i should have realized that when i saw the 8% slip it come's with age and looking back at this thread i realized i had put a effective 24 pitch on.
There may be hope however this boat was moored and there was some growth build up on the hull with that cleaned off a new carb and a dual plane intake and a bit more tinkering along with a whim and a prayer...4600 here i come..
Sometime later this boat hit 58mph the turbo was a success at about 8% slip.
