NeXt LeVeL
Thread starter- Joined
- Feb 20, 2008
- 2
Hey all, I just purchased a 1985 Chaparral 200XLC which has a 260hp Mercruiser engine. The boat sat for a few months in a tow yard and the owner of the yard knows NOTHING about this boat. I believe the engine had a starting issue because the starter isnt in the boat. All the plugs on that same side were taken out as well, so I think I wanna do a compression check. My question is this... How do I go about turning the engine over without a starter. Can I manually bump the engine over using a breaker bar and socket on the crank pulley? Does the drive need to be in reverse/forward/neutral or does that matter? This engine is a CCW rotation 350ci. Should I take the belts off the front to make it easier to spin? If it doesnt budge should I squirt some lube into the cylinders? Should I do that anyways? Any insights/suggestions?
~Joey
~Joey
