Turns over cant get her to fire up
lonemust
Re: Turns over cant get her to fire up
No problem. Hopefully he checks the vavle adjustment the old school way. Just seen the last pic you posted the rotor is pointing right this time. So if you got good spark and fuel it should fire up. If the engine seems like it turns over too fast then I would say the valves are still to tight. Your buddy should be able tell by sound of the engine and by checking each rocker. If I was near by I would look at for you. Normally If they are to tight I can see it with the valve cover off. Of course I know what I'm looking for, it's something you learn by hands-on experince not though text books or someone telling you. To me it's hard to explain in words how I do it.
let us know if he gets it fired.
atomb
Thanks Lonemust -my guy should be here in a half hour so Ill let you all now what he has to say Thanks for everyhting so far
atomb
well my buddy thought that the rotor was a bit off and then took a look at the valve nuts and said we need to deal with this first.... so we did the valve adjustment and Im pretty confident it was done correctly as per the manual
it took some time but it was all logical assuming you know exactly which valve is exhaust and which is intake ..we were able to verify thius using the old gasket... So valve adjustment seems to be done correctly...
It was getting late for him and he had me crank it to see what was going on... we noticed a small amount of fuel leaking from the gasket at the carb....
by the way the engine did not want to fire up still.....
So Im goin to do a compression check on the cylinders tomorrow
He told me that plugs are saturated ...could be a problem....
other issues ---we were a little surprised that oil was not jumping out by the valves .... that observation didnt make feel to good.........
so end of long day with a little bit of eductaion to show and no thunder...
So it goes ...I will continue this thread till the engine works or i blow it up...
Thanks for Helping especcially big thanks to Lonemust really thanks man most appreciated..
atomb
runninng a compression test on her today -i need a little help understanding -i know its simple but i have never run it before... Ok when I do the first cylinder the psi jumps from 100- 160 depending on how long i crank the engine. Im alittle confused. At the end of the test seems to be that all cylinders max at 160 psi
any thoughts fellas?
atomb
By the way this engine has a new ring job performed by me and with 160 psi I believe after i get her started and some wear in it will be at 140 ...please correct me if im wrong ..
Now i believe I might have really fouled the plugs up fom too much gas so ..well see.
Today i threw back on my old carb to make sure im getting fuel.
So Ican check off compression and fuel and i guess that leaves spark
I thought i had it under control but obviously not.
atomb
UPDATE::::Re: Turns over cant get her to fire up
:D Got her to fire up today .The angles are singing .......
I told my buddy at my parts place my whole story and something i left out when i told my story here i was turning over the engine by bypassing the igniton and jumping the slave solenoid on the starter . My buddy said go back to the boat and turn the damn key dopey. And like a sob she fired up. I want to thasnk everyone here for the help ands support I learned so much in the last few days
I will be tackling the outdrive this week, buckle up :)))))
6meter
Not trying to be a smart***** atomb, but outdrives are ALOT more to them. lol
A quick way to get TDC #1 compression....stuff a rag in the sparkplug hole and click the engine over 1/4 turn each click. The rag will pop close to TDC. Glad you learned somethings this week.
atomb
I have no delusions of the outdrive being 1,2,3.. Actually Im anticipating many hours of frustration ,bloody knuckles ,cursing and crying. But Im determined to go boating this summer. Ill need all the luck I can get. Hopefullly this thread will help some others out....
lonemust
It always helps to turn the key ON when triing to start an engine.lol
atomb
Well said ....what a bonehead these guys who cant tell the difference betwen a screwdriver and pair of pliers ...:redface::redface::redface::redface:Thanks lonemust
6meter
OK, whats up with the outdrive? Keep the key OFF here.
atomb
gotch keys off --
Havent started to do anything yet... Going to do regular maint new impeller look inside see how it looks...... changeing bellows and new shift line.. Not starting on this for a bit.... Ill let yo know when i get there. Thanks for the interest:)
