Twin 2.6 omc outboards
Doug hicks
Well update it was the stators so problem fixed . But I have another problem both motors start and run good for about 1-2 minutes and then just die but will start right back up . And run the same amount of time then die again .It don't sputter just like I turned the key switch off , so it don't seem to be a fuel issue. I'm lost again any info would be greatly appreciated . Thanks !
clemsonfor
Are you sure the kill circuit is ok. Maybe disconnect the black yellow wire to rule out the ignition switch or kill switch? Just throwing out random thoughts. It would be really weird that it would cut off and start right back up, you would think everynow n then you would get a time it might not restart right away cause the short would still be shorted . Worth a try maybe?
Doug hicks
Well I figured it out somebody did away with the automatic oilers and didn't unhook it at the motors . Unhooked them and everything seems good . This boat is new to me so just kinda figuring everything out . But thanks for the info
