Twin 2002 150 Johnson decreasing performance
G DANE
Re: Twin 2002 150 Johnson decreasing performance
I you use a single controller of the type that has a split to two cables, is can be out of order somehow.
roy w. shakun
thankyou for the suggestions, i will respond after the following in order has been checked and re checked. over and out! <br /><br />carbs<br /><br />throttle and linkages, controller<br /><br />alignment<br /><br />test props<br /><br />( compression checks )
G DANE
Hi again Roy<br /><br />Now i surely would set a limit on what to investigate on that new motors, you are under warranty. I would draw the line at just looking and checking - not loosening a screw. Someone had the deal of a month ( or the year ) selling you the motors, and you deserve a lot of service and support from him. Take him for a ride and show him the facts.
