Twin '87 Black Max 200 & single battery??
donzi gt230
First off, thank you guys for the help and making my boat tinkering day quite productive!!
I'd like to know if it's safe for these charging systems to run two motors on a single battery. If not, is there a way to run an isolator and 'fool' the system into overcoming the voltage loss of the isolator? Maybe there's a better way to get both to charge one battery that's not too expensive or complicated? Ideally I'd like to run one starting batt. and one house batt. and have both motors charge both batteries. I'd use a combiner or relay to isolate the house from the start batt. while not running. If it's not feasible I'll stick to a more traditional set-up.
j_martin
Re: Twin '87 Black Max 200 & single battery??
If they're still the original 16 amp systems, I wouldn't hesitate to hook them both up to the same battery.
One of the reasons for multiple engines is redundancy, though. Separate batteries would give you redundancy in the system most likely to fail when needed, like an engine start 10 miles from port.
hope it helps
John
