waterone1@aol.com
- Joined
- Oct 10, 2004
- 1,235
This is going to be a long one, please bear with me, any help would be appreciated. Ok, first, this boat is new to me, so I do not have any history to compare to. The symptom, or problem is that the port engine will not produce the same power or top rpm's at WOT. The starboard is hitting 4800 the port 4000-4200. The engines are 1999 Merc 454 magnum horizon mpi's, serial numbers 0L086966(port), 0L086965 (starboard) both have about 260 hours on them. The engines are coupled to V-drive down angle transmissions and are turning 4 blade broze props. Both props were sent off to be checked and matched prior to me launching boat. Also prior to launching boat, new spark plugs, caps and rotors were installed in both engines, compression was checked on all cylinders, all were between 130- 150. I have run two tank fulls of fresh gas and the fuel/water seperators have been changed twice. I have pulled each plug and tested it on it's wire to insure that each plug is firing. I have run the boat under load with a fuel pressure gauge hooked up to the injector rail, it is maintaining 40 pounds of pressure. Base timing was checked on both engines (with ecm set to base timing mode)both are at 8deg. I have run the boat(with someone else driving) through the rpm range with a scan tool and timing light hooked up and verified it is advancing up to 32 deg. There are no trouble codes in the ecm. While running under load both engines appear to be matched untill 2500 rpms, from there up the port throttle must be pushed further to maintain same rpms. I recorded all of the ecm data while running, and all I can tell is that the port engine is working much harder to produce the same rpm as the starboard, for example at 3500 rpm's the port is at 64% throttle with a tps voltage of 2.99, while the starboard is at 47% throttle with a tps voltage of 2.37. The Map is showing likewise. Prior to launching the boat, I did a power balance test on the injectors and replaced two, low flowing injectors ( on this engine), retested and all was fine. There are no leaks around the injectors. I have looked through and followed the troubleshooting in service manual # 23 and cannot find anything. Just for the heck of it I swapped ignition coils between engines....no change.The only test I have not done yet is to put a vacume meter on the intake. Does anyone have any other suggestions or ideas ??
