JoeMan
Thread starter- Joined
- Jun 29, 2006
- 332
My Merc 60 outboard is missing the trim tab (that's what I believe it's called), the little fin above the prop on the bottom of the cavitation plate. My understanding of the fin is that since the prop spins in one direction causing the motor to pull to one side, this little fin counteracts that pull while the boat is in motion, and also assists in low (no-wake) speed steering. Well, mine is missing. I was told by a well intentioned boater that with a boat as small as mine (16 foot aluminum runabout) that I could buy either a replacement fin for it, or a 'plug' which basically fits in there and makes the bottom of the plate flat instead of having the fin. Suggestion there? I am inclined to just get a new fin.
Secondly. I also have a hydrofoil on, and the nut ends of the bolts come through the bottom side of the plate. Should these bolts be turned upside down so that the water pressure from the prop is only pushing against round bolt heads instead of the nut and bolt ends?
