Re: Two Cycle Oil
The Merc Premium Plus is excellent oil. The ash components in it are practically not worth mentioning, especially if the outboards you're pulling down run at slightly higher temps. The fact you're not seeing any build-up is a sign the small amount of ash is being burned and blown out. Hopefully the reason you're having to pull the engines down in the first place isn't a result of the oil burning too clean. I just don't think you can wrong these days with any TC-W3 oil in an outboard.by achris - This is in direct contrast to what I see when I pull engines down. The engines with the least buildup are running Merc Premium Plus.
