BoatBuddy420
- Joined
- May 24, 2002
- 6
I have a 1986 90 HP Johnson VRO. The #1 and #3 cylinders are firing at the same time. I indexed all cylinders on the flywheel and checked them all with a timing light. When i check the #3 cylinder the #1 mark is seen right next to the #3 mark and they are exactly 180 degrees from each other on the flywheel. I changed the flywheel, stator, timerbase, powerpacks, plug wires, and plugs. still no difference and running out of ideas...
