Two little questions.
sogood
Where do the rocker cover vent hoses go to? Mine only has one on place and it just floats loose. Thought I read somewhere that they go up to the carb somewhere. Secondly, should I expect my gear change to be stiffer when the engine isn't running? Thanks in advance.
Ayuh,.... The vent lines go to the outside of the flame arrester,....
The air goin' by sucks the fumes into the motor,...
Changin' gears without the motor runnin' can be tougher, yes,...
Agree and will add if its a Bravo drive it can be very hard and if its forced things can be damaged
